Prop shaft run-out >
Prop shaft run-out
Prop shaft run-out
Old 06-24-2022 | 10:08 PM
Default Prop shaft run-out
What allowable runout for a standard Bravo prop shaft. Last weekend a submerged log jambed between the prop and cavitation plate. When I put it in reverse it stalled the motor instantly. Found the cavation plate broken. Checked the shaft and have .0035-.004 runout towards the end of the splines. Up close it's out about .002.
Smitty275 is offline
Old 06-25-2022 | 06:21 AM
Most say .005 is max, with .0035 or under preferable.
Baja 252 Islander
bajaman is offline
Old 06-25-2022 | 12:13 PM
Ayuh,..... At the aft end of the shaft, the threaded end,....
Bondo is offline
Old 06-25-2022 | 07:36 PM
Veteran: Navy
Clean the shaft up and polish it with 220 Emory. And you probably have a run out of .005
AmiableDave is offline
Old 06-26-2022 | 06:49 AM
Which leads us to the next question; Can it be straightened with a block of wood and a BFH?
thirdchildhood is offline
Old 06-26-2022 | 07:03 AM
Active Streak: 30 Days
No and why? You stated .0035. Spec is .005
Helmwurst is offline
Old 06-26-2022 | 07:36 AM
Small bottle jack. Keep dial indicator on to measure deflection. Probably not the right fix(replace shaft) but can be done.
liberator221 is offline
Old 07-06-2022 | 09:03 AM
blownhammer2000 is offline
Old 07-06-2022 | 09:09 AM
This was our test for an insurance claim, was tested on the drive by the adjuster, he showed. 006, within spec, but did the test behind the splines, we pulled it apart, checked it as you see it, claim reversed
If it's out of spec, replace it, no way I would ever try to bend it back, you could damage bearings and a whole lot more trying to safe a few bucks
Old 07-25-2022 | 02:51 PM
I would inspect your gears, you may have cracked a tooth. I had a similar situation, except no visible damage until you pulled the prop off. Inspected everything in the water after I felt a thump, no visible damage so I kept boating. Prop shaft and vertical shaft both had a twist in the splines. I found that out after the drive grenaded and I pulled it off to get repaired. Lesson learned, when you feel a thump, pull the prop.
ThisIsLivin is offline
