No reverse(forward) in bravo drive >
Old 08-20-2022 | 09:43 PM
Default No reverse(forward) in bravo drive
Last weekend the bracket for the upper shift cable broke and my port drive was stuck in forward. finished out the day by shutting off the port engine when I needed neutral. Ordered a new bracket and installed it and adjusted cable. Still stuck in forward. Pulled the back cover and found the 1/4-28 socket head bolt had fallen out. Bolt was damaged, both threads and head had deep marks like it was jammed up somehow. I replaced the bolt and again adjusted shifter with alignment tool. I did take off the belt and ran engine for a minute and it seemed to shift into and out of all positions fine. Took the boat out this weekend and it worked great in forward and neutral, but found it did not actually engage in reverse. Went out to a safe spot in the lake and attempted to get it in reverse by removing the upper cable from the bracket and forcing the lower shift cable all the way back till it bottomed. Still no reverse. Forward and neutral worked great. Loaded boat and got it home to the barn. What could cause this? Can the clutch work in just one direction? This is the port drive so it would be forward that is out on a normal rotation drive, if that makes any difference. When I had the top and back cover off last weekend everything looked fine and there was absolutely no metal on the drain plug and the oil looked like new. Hopefully the drive experts on here know of this issue and it can be fixed easily...
Shotgunn is offline
Old 08-21-2022 | 11:11 AM
Is the shifter in neutral? if so, something in the shift cable/ linkage appears out of order,
the bolt head in the shift lever should be facing straight back, basically aligned with the the
”l” between the 9&4 on the back of the case
JaayTeee is offline
Old 08-21-2022 | 11:50 AM
Thanks,
I think when I took this picture the drive was in forward, and the bolt was out. when I installed the new bolt, I was able to actually shift the drive into neutral. Then performed the alignment with plastic tool, per the instruction. I had positive shifting in all 3 positions at the helm. I did not actually check to see if the prop was spinning in both directions, and did not notice it was in fact not going into reverse until I was maneuvering in to tie up to another boat. I can drain the fluid, pull the cover and see if the bolt is aligned with the line on the case. To be clear, the rusty bolt, recessed in the arm, in the above photo?
Shotgunn is offline
Old 08-21-2022 | 05:55 PM
Yes, the rusty bolt in the bottom, that recess in the lever is where the detent ball in the back cover rides when it’s in neutral.
when the lever is retracted by the cable, it’s rotating the shift fork cam to push the cone into the top gear, which will turn the propshaft ccw when engine is
when the lever is extended by the cable, it rotates the shift fork cam to push the cone into
the bottom gear, which will turn the propshaft clockwise
JaayTeee is offline
Old 08-21-2022 | 08:02 PM
Had the same issue you describe. No reverse on one of my bravo 3 drives. Replaced cable, shift arm etc. Still no reverse. Pulled the shift cones & the shift fork, (flat piece that moves the cones up & down). Cones were spotless, springs were good but the shift fork had a groove worn on one side & wouldn't move the cones fully to reverse. Replaced the fork, works perfectly.
smashm is offline
Old 08-22-2022 | 06:32 PM
Oh, and use loctite on the screws
JaayTeee is offline
Old 08-22-2022 | 08:43 PM
The bolt is lined up in neutral( and was thickly coated in blue locktite). It rotates to the left of the line when helm is in forward, but since I cant be in two places at once, I cant watch the round thing above to see if its actually moving down.
Shotgunn is offline
Old 08-22-2022 | 08:52 PM
How hard was it to get the cone out? Special tools required? I have pullers at work, but nothing that will fit down into that case around that gear. I ordered a #28 manual (on cdr/pdf) but it wont be here till after the weekend. I have never been into a drive before, I was hoping it was something common and simple. The boat is functional as it is now and I can use it for labor day weekend, and any other remaining weekends of the season. Removing the drive and trying to obtain uncommon parts, will likely end my summer.
Hopefully by next season I will have a much better understanding of the bravo drives.
Shotgunn is offline
Old 08-22-2022 | 10:31 PM
Here’s something easy to try.
remove the bolt out of the lever and the shift cam, you can use that same bolt and thread it into
the shift shaft at the top and pull out the shift shaft and shift fork, put the top cap back on.
You can look over the cam and check it for wear too.
you should be able to see the shift cone groove(where the fork rides) you should be able to pry it
either up down, once you start moving it, the garter springs inside will snap it either up or down.
when it is in the top gear, rotate the propshaft CCW, it should spin, try to rotate it
clockwise, it should lock up with very little amount of rotation and not turn
move the cone to the bottom gear, the propshaft should spin when turning clockwise and lock up
when turning CCW.
If it locks up one way and rotates the opposite way, the clutch is doing
what it’s suppose to do…..it would point back to a cable/ adjustment
or a shift fork issue.
when you put the shift fork back in, the nuts face down.
To get at the cone, you have to
have the drive off, the input shaft/pinion gear out of the case, the shift fork out, then then you can remove the driven gear cluster, after its out,
stand it up on the splined end of the clutch shaft, push down on the top gear hard enough to compress the garter springs, the gear should move down, then you can tap the collar on the clutch shaft down and remove the 2 keepers, then the collar will come off, the upper gear, then the top garter spring and then the shift cone.
JaayTeee is offline
Old 08-23-2022 | 09:11 PM
when turning CCW.
I may skip the 2nd part(cone) till after the holiday, but I will pull the shift out and do the check. Thanks for the help, I will report back with findings.
Shotgunn is offline
