-   -   Cavitation...Swapped TRS with Konrads (https://www.offshoreonly.com/forums/drives-lower-units/379378-cavitation-swapped-trs-konrads.html)
CaptainChazz 05-26-2023 11:36 PM
87 Chris craft stinger 390 X. Owner replaced
https://cimg8.ibsrv.net/gimg/www.off...3ae8166eaf.jpg
the original TRS drives with Konrad's and injected 540s. I'm assuming in the stock location. The boat comes out of the hole OK but appears to be cavitating until it is up on a plane. My initial thought is the drives are not far enough down in the water. Thoughts?
JaayTeee 05-27-2023 06:33 AM
Those appear to be Konrad HP’s, they’re just under 2” shorter than the
TRS, this may happen when getting on plane, it’s a trade off for better performance at top end.
jeff32 05-27-2023 06:46 AM
I once drove a boat that was doing it too. Complete different boat though... i was putting tabs down and /or turning left and right to rock the boat from side to side so the prop could bite more, not perfect but it was the way that helped!
Craney 05-27-2023 08:04 AM
Get a set of these
https://cimg0.ibsrv.net/gimg/www.off...a4d92299a.jpeg
https://cimg7.ibsrv.net/gimg/www.off...aca8e3121.jpeg
CaptainChazz 05-27-2023 09:34 AM
Oh I see. So I'm assuming with powerboats this would be considered normal? My first thought was it needs bigger props but I don't think they could be more than an inch and a half longer blades.
CaptainChazz 05-27-2023 09:36 AM
Those look nice. Were you having the same issue?
F-2 Speedy 05-27-2023 09:39 AM
There is nothing wrong with a little cavi when getting on plane, mine break loose around 3500 just pull the sticks back a bit and they'll bite
CaptainChazz 05-27-2023 09:43 AM
Well it's good to know it's normal. I've owned a bunch of boats but never a power boat so I've got a bit of a learning curve ahead. As a drag racer (bracket racing) we don't like slippage of any kind 😂
JaayTeee 05-27-2023 12:04 PM
My boat had the propshafts 3” below the bottom of the boat.
They key to getting it on plane was to not exceed 3200 rpm’s, if you did,
it would blow out and you would have to let off and let it get hooked back up, or start over, if you kept it below 3200 rpm, it came on plane every time.
You might want to try and figure out if you have a particular rpm on yours
where this occurs
CaptainChazz 05-27-2023 12:55 PM
where this occurs
good information. Thank you.
