-   -   Arneson ASD6 info (https://www.offshoreonly.com/forums/drives-lower-units/379512-arneson-asd6-info.html)
Tartilla 06-07-2023 03:19 PM
Arneson ASD6 info
Arneson ASD6 information.
I managed to complete a good deal on a 1986 Cobalt 300 Condurre, with Blow BBCs, and Arneson ASD6s.
Hull has 144hrs (original TRS boat)
Arnesson drives and B&M 420 Blown BBCs have about max 50 hrs.
​Boat has sat for 30 yrs.
Arnesons look pristine after I washed the algea off.
My issue...is that I have zero info on the ASD6s. Prop nut tq?? Things like that. Fluids etc.
These props turn in. Not sure if that is the best, vs out.
Rolla 5 Blade props.
Orig owner said he sourced better trannys...I'm assuming he got them from BAM or something.
This was all done in 1991 ish.
Does anyone have an ASD6 service manual? Lots of info online for the 8s and7s...but the 6 is a little obscure.
I originally snagged this as a potential drive and engine setup for my Formula 233, but the boat is in good shape, so we'll do the refit.
The Condurre 300 needs to go on a diet...
Art
Tartilla 06-07-2023 03:22 PM
The BBC tags (he got crate 454s for the new arnesons)...
...are PCM engines. Anyone have any info on the early 90s Pleasurcraft Marine Engine Co and what these might be for internals?
Tartilla 06-07-2023 03:37 PM
https://cimg1.ibsrv.net/gimg/www.off...1bdc2e0531.jpg
https://cimg8.ibsrv.net/gimg/www.off...9d3e2e034c.jpg
These pics are how it was when I received it. Some light soap and water has cleaned up 95%.
​​​​​Th
Fresh Water boat. The Arnesons and BBCs never saw salt.
Raw water cooled.
Will need to find a place for heat exchangers.
I need to figure that put before I pull anything out.
green lightning 06-07-2023 05:03 PM
The original Arneson conversions came with asd6 drives .
https://cimg0.ibsrv.net/gimg/www.off...90654c0355.jpg
bajaman 06-07-2023 06:47 PM
Pretty amazing boat, it will be cool to see it restored and plying the waterways again!
Tartilla 06-07-2023 09:15 PM
Yeah, it shouldn't be too much to do. Way less than the Formula 233 Project. I need to source more TRS drives and Merc Trans to fire that one up. Formjla needs a trailer as well. Easier to import one from US than build one here. Any new BC trailers need electric or elec hydraulic over 6000lbs.
Expensive and bigger maint.
Tartilla 06-07-2023 09:27 PM
Thank You.
Trying to read the pic..but it likely came in as a thumnail size.
We're a Glen-L boat building family. Fiberglass is a fairly common occurrence around here. Not keen on a Marine Surveyor digging around either...lol.
green lightning 06-08-2023 07:16 AM
https://cimg4.ibsrv.net/gimg/www.off...15e14e3b01.jpg
bigger picture
green lightning 06-08-2023 08:09 AM
The maintenance instructions are for the conversion kits and I don't know how your engines are attached to the drives
https://cimg7.ibsrv.net/gimg/www.off...1991b618d0.jpg
green lightning 06-08-2023 08:13 AM
Do your steering rams touch , they almost look like from the picture like they are to long .
resurrected 06-08-2023 09:19 AM
I have reached out to Rik for the Arneson project I am involved with. He has been extremely helpful with technical information and parts.
tommymonza 06-08-2023 11:19 AM
I shade treed my buddies Pleasurecraft 454 it was 350 horse from factory nothing special for internals.
Tartilla 06-08-2023 04:20 PM
There is a good inch of gap between the steering cylinders.
​​​​​Good catch though...it's those little things that can save a world of hurt.
Are these steering cylinders setup correct for the thrust of the prop?
I heard heard that the thrust side of the drive needs to have the cylinder pushing against it, so the cylinder piston has full surface and pressure, vs the reduced force from the cyl rod in the way.
I think these are correct with the props turning in...the port drive gets thrust inward...and the cylinder piston is one the correct side.
Tartilla 06-08-2023 05:52 PM
Yeah, exactly what I was hoping it wouldn't be...lol.
I was thinking of getting one on a dyno, but if it's not anything to write home about...then prob not worth it.
I was at least hoping for forged cranks and some reasonable heads.
Opens up options to other lighter options.But I'll rune these first.
Thanks Thanks good Int.
Tartilla 06-08-2023 11:32 PM
https://cimg1.ibsrv.net/gimg/www.off...b8630bd444.jpg
Anyone recognize the transmissions?
Tartilla 06-08-2023 11:34 PM
Looks like the TRS Merc 400 bellhousing was kept, and another trans bolted on.
Scarab Arneson 07-10-2023 02:18 PM
nice
Tartilla 07-25-2023 02:27 PM
Turns out trannys are Doug Nash Marine.
DNE2 is their Logo.
Hydrosmooth is their Marine trans nomenclature.
This one is Serial 0006. I don't think many were made.
Huber had some parts for these, if anyone is looking back into the OSO archives in the future.
Art
Swamplizard 07-28-2023 10:47 AM
Nice project?
I am looking for propellers for my arnies...19-spline. What diameter and pitch if selling em?
Tartilla 08-19-2023 07:58 PM
Cleaned her up. I may need to fabricate an Arneson ball socket nut wrench.https://cimg8.ibsrv.net/gimg/www.off...f91af67cbe.jpg
