Bravo 1 question
Old 08-24-2023 | 11:00 AM
Default Bravo 1 question
Ok I picked up a complete bravo 1 drive. Trying to figure out the gear ratio by the SN
transom number is OD 3355167
the SN on the upper is OD 329093
thx
suicidealli is offline
Old 08-24-2023 | 04:15 PM
Mark the drive shaft and prop shaft, put in gear (F/R doesn't matter)
Rotate drive shaft 10 times and count prop shaft turns then divide by 10
AllDodge is offline
Old 08-25-2023 | 02:27 AM
0D329093 = 1990 Stern Drive R BI-ROTATION BRAVO 1 [1.50:1] Model number 5120150CS
BRAVO DRIVES - 0B664190 THRU 0F729999 (mercruiserparts.com)
lakematdude is offline
Old 08-25-2023 | 08:31 PM
Thank you.
Old 08-26-2023 | 09:06 AM
Active Streak: 30 Days
^^^^^ As long as someone has not changed the ratio
Helmwurst is offline
