SSM 6 Gimble Dimensions >
Old 01-05-2024 | 08:30 AM
Default SSM 6 Gimble Dimensions
Happy 2024 everyone!!! Can anyone supply a SSM #6 gimble dimension drawing? Or does anyone know exactly how wide a #6 gimble is?
rob vanharten is offline
Old 01-05-2024 | 07:50 PM
I have this and I can measure if you want ... you want the widest point?
ICDEDPPL is offline
Old 01-05-2024 | 10:09 PM
I found that drawing as well. If you wouldn’t mind measuring the widest point I would appreciate it. Thanks Dan!!
Old 01-05-2024 | 10:34 PM
You`re looking at about 15" Rob.
ICDEDPPL is offline
Old 01-06-2024 | 04:41 PM
Thank you sir!
Old 03-08-2024 | 01:53 PM
Hello all. I have a Bravo 1 that I replaced the ram line diaphragm re-attached the lines and then I had a bunch of water coming in by the elbow for the water pick-up. I Marine Tex that and it sent the water down to by the flywheel. A mechanic said it was probably the Gimble Plug which I didnt even know existed and said I should take off the diaphragm I 5200ed into place and its up there and need to replace/5200 that. Do you guys have any diagrams or know exactly where I am looking?
Thank you so much brothers!
Sonicfrank is offline
