-   -   prop in tunnel (https://www.offshoreonly.com/forums/drives-lower-units/385002-prop-tunnel.html)
stuarth 03-21-2025 09:09 PM
prop in tunnel
just completing my drawings
26 ft trailered,
Cummins 355 diesel
44 degree deadrise station 2
27 midlength W.L
1100 l fuel , just in case
speed max 43 knots half load
30 knots cruise
prop in tunnel enables ramp splash
cannot post drawings, site will not allow
boostbros 03-22-2025 07:24 AM
prop in tunnel was used by penn yan and really sucked but you could get into shallow water
JaayTeee 03-22-2025 07:46 AM
44 degree dead rise… at the transom?
The prop tunnel isn’t good for lift,
( for a planing hull) neither is a 44*
dead rise, I’m not seeing this getting
to 49 mph.
Tartilla 03-23-2025 10:57 PM
26 ft trailered,
Cummins 355 diesel
27 midlength W.L
30 knots cruise
Take a screen grab or convert your plans to a jpg and then post.
Tunnels behave a bit like a jet system. A shrouded prop at the very least.
https://cimg3.ibsrv.net/gimg/www.off...6fc6ceaf07.png
A 44° deadrise means your hull has almost a 90° vee. Not great for lift, shallow running, or stability. Maybe it was a typo?
Are you proposing your prop tunnel location where the delta pad would be?
Let's see some pics.
