Mercury Bravo One XR >
Old 05-07-2025 | 04:59 PM
Default Mercury Bravo One XR
Was on the water traveling about 35mph when it felt like the prop came off. Check still had prop but no thrust. Prop spins but hard to turn with both hands and it feels rough when spinning.
Jfigari is offline
Old 05-07-2025 | 05:54 PM
Veteran: Army
solid hub or rubber hub prop? If rubber hub, sounds like you spun the hub.
DrFeelgood is offline
Old 05-07-2025 | 07:30 PM
Checked that also. Hub is good.
Jfigari is offline
Old 05-07-2025 | 07:43 PM
When the engine is running, does the shifter move as normal?
JaayTeee is offline
Old 05-07-2025 | 08:47 PM
If you're lucky, you only broke the vertical shaft. Drain the lube and see how metal comes out.
Griff is offline
