TRS U-joint interchange 1320?
Donzi Hornet III, BW transmission, TRS drive, I've got a good knocking when I'm cranked hard over, so am replacing the U joints. I saw a post stating that the TRS uses spicer 1320 joints, but can't find any info on a 1320. Does anyone have a cross reference, Are there newer better quality u joints I should be installing? I've found a Sierra replacement, and a replacement that says its a mercruiser part 94-01821,
I'm looking at the 1310, it has the retaining ring on the outside of the u joint, mine are on the inside...unless a 1310 comes with either cap, this is going to require more digging
