Found drive lube in bellows
Pulled my bravo one off for some regular maintenance, greasing u joints, etc. found a 1/4 cup or so of drive lube in the bellows. I can only assume it’s from the input seal. Took a look at that, and the input yoke is hard running the seal. Seems to me the previous rebuild didn’t get the seal in all the way, or there is a shimming issue on the input shaft. Doesn’t appear to be rubbed through as I can still see part numbers in the face, but seems to have been rubbing for the roughly 30 hrs since I got it back. Is this an emergent issue or chances I can run it until October or roughly 20 hrs feasible? Then pull for the winter to get fixed?
I would say if you have no slop, in out movement of input shaft, I would say you are safe to run it, just keep an eye on oil level.
I have a formula 311 with twin bravo one and my one drive was leaking oil bad enough on input that I could see it in the bilge. This is the time period when I just bought the boat and the previous owner told me how he had to keep filling the gear lube. He ran it and I ran it the remainder of that year, maybe 10 or so hours by me that year and 5-10 hrs that year previous owner. When I pulled it, I had in out movement this why my seal was tore. (Input nut came loose and things moved around). My point is I ran mine with slop on input (not knowing at time) and it carried through the year. Then I rebuilt the drives.
So I think you’d be fine. Of course it’s not the desired path to take, but if you know about it and have a plan and you have no end movement, run it snd watch the oil level.
hope this helps,
Chris
hope this helps,
Chris
I probably will run it. Likely about 10-15 hrs this year. Just dumb that the yoke is rubbing the seal. Looking at my log, this is 25 hrs after a new upper gear set.
just checked for end play. I have zero.
The new seal is in and so far so good. It wasn’t a difficult fix, you’ll just need some special tools like the spanner wrench and an in-lb beam style 1/4” torque wrench to set the preload.
