Gear oil concern
Old 11-16-2025 | 02:30 PM
Default Gear oil concern
Drained Bravo 3X for first time on boat I bought this summer. Fluid was dark in the center and tan on the edges. Gold dust throughout the fluid and same situation on both drives. 550 hours and 8.2 Mag HO stock.
drives have typical reverse clunk, smooth shift going forward using throttle only. Light clunk forward with joystick.
thoughts?
Dalyons03 is offline
Old 11-16-2025 | 10:12 PM
Looks like water on the oil. Better have it taken apart and refreshed before it goes boom. Cheaper now than later.
SutphenSteph is offline
Old 11-17-2025 | 08:24 AM
thanks was thinking similar…time to get out a wad of cash…ahh…
Old 11-17-2025 | 11:53 AM
Dalyons,
B ust
O ut
A nother
T housand
Thanks. Brad.
Brad Christy is offline
Old 11-17-2025 | 02:14 PM
How did the drain plug Gaskets look? Could be as simple as water getting past those, but probably a good idea to pressure test the drives.
Ryanw10 is offline
Old 11-18-2025 | 09:45 AM
Veteran: Navy
Is that corrosion all around the plug?
or a bad picture
Does boat sit in water or is it stored on dry land
you could pressure check it
Flush it
Recheck
powerboatr is offline
Old 01-01-2026 | 02:41 PM
I specialize in custom built bravos that withstand some hp and I obviously do factory rebuild, width, and without upgrades. If you’d like to have me service it or need any other help feel free to call or text me. 508-631-4784.
adrenalinejunkey is offline
