Imco -2 lower question >
Old 01-07-2026 | 05:47 PM
tripps's Avatar
Default Imco -2 lower question
How manny rpm would you pick up wen u put on a -2 lower on a single 30 V bottom with a pad 6500 lb boat 502 500hp 1.5 gear ratio bravo 4 blade prop lower is about 4 inches below pad now. TIA
tripps is offline
Old 01-07-2026 | 08:43 PM
My guess is you won't even be able to get on plane with a -2 lower and Bravo prop.
Griff is offline
Old 01-08-2026 | 02:43 PM
tripps's Avatar
Default Lower
It has a bravo now plane s off without even touching tabs!!!!
tripps is offline
Old 01-08-2026 | 03:15 PM
F-2 Speedy's Avatar
what rpm are you turning now ? current prop pitch
F-2 Speedy is offline
Old 01-08-2026 | 08:39 PM
tripps's Avatar
Default Imco
5800 24 bravo I know I need more prop
tripps is offline
Old 01-08-2026 | 08:53 PM
F-2 Speedy's Avatar
Im surprised its still together..............id get the revs down around 5200 5300.........maybe a 28-30 pitch, then address the drive issue
Old 01-08-2026 | 10:34 PM
Going from 4" below the bottom to 2" below is a huge change. Most single engine V's are set up in the 3-5" below range.
Griff is offline
Old 01-09-2026 | 05:13 AM
I agree with Griff. You can install an IMCO SC -2 lower but you'll probably end up with a 1-1.5 inch spacer. I do like the IMCO SC lowers though, very little drag.
SecondWind is offline
Old 01-10-2026 | 01:08 PM
tripps's Avatar
Default Imco
Thanks guys ill let u know how it worked in June!!!!
tripps is offline
Old 01-10-2026 | 04:59 PM
i put a 2 inch shorter sportmaster on our 25 foot thunder and lost the fun of overtrimming and winding it to the moon nothing sounds like a na bigblock wound up to 7000rpm it still slides on plane with no effort, it was more fun with it deep
boostbros is offline
