Go Back  Offshoreonly.com > Technical > Electronics
Add another battery for sound system? >
Old 02-06-2014 | 01:46 PM
Default Add another battery for sound system?
I have a Nordic Rage and currently two batteries. The stereo now is 3 larger amps and it seems that after 4-6 hours of no motor listening they will not start the boat. Should I add a third or am I just expecting to much?
pluguglyinhere is offline
Old 02-06-2014 | 05:22 PM
US1 Fountain's Avatar
Ginger or Mary Ann?
Put a 3rd battery as your starting battery only. Keep it isolated from your stereo batteries. Very easy to do. Search Blue Seas Battery Relays
US1 Fountain is offline
Old 02-07-2014 | 10:09 AM
Yep - what he said! I did same install last summer, and it works very well.
ALL_IN! is offline
Old 02-07-2014 | 10:40 AM
Ginger or Mary Ann?
http://www.defender.com/product3.jsp...0060&id=750169
Old 02-07-2014 | 08:53 PM
+1. That's how mine are ran. My batteries for the stereo are Kinetik Powercells and they have performed excellent.
Plowtownmissile is offline
Old 02-07-2014 | 09:23 PM
ROB FREEMAN's Avatar
kinetics rock .. hc 2400 baby ,they need a hard charge though ..
ROB FREEMAN is offline
Old 02-08-2014 | 10:26 AM
I have 2 dedicated starting batteries, one for each engine, and added Blue Sea Systems battery Isolator for my 3rd Deep Cycle battery for the stereo. I’ve got six seasons out of that setup with the Deca Marine Deep cycle battery.
johnny b good is offline
Old 02-08-2014 | 11:01 AM
I used two group 31 Deka AGM deep cycle batteries wired parallel as battery #2, and battery #1 was just a standard marine starting battery. So both of the AGM batteries worked as one. This provided a solid 10 hours of 3/4 volume on a 2700 watt stereo. The alternator won't charge these monsters so I had a shore power 30amp charger hooked up to charge the "house" batteries. This was on my previous boat. I will be wiring up my new boat in the same way, except I might be adding a third group 31 to the battery bank... I will be running a rockford Fosgate Power T1500 to 2 Rockford 12s and a power t600 to 4 boston acoustic pro se60 6-3/4 components, along with 4 infinity 6x9s wired to a JL 150 watt amp...... More power, more power....
low_psi is offline
Old 02-08-2014 | 04:19 PM
Ginger or Mary Ann?
That way requires you to switch the battery switch to #2 every time you want to play your stereo and not worry about running your start battery down too though. Why not install a battery relay in your new boat to avoid remembering to always switch your battery switch from 1 to 2, and then back again, and let it keep both systems separate all the time, except when charging, all automatically?
Old 02-10-2014 | 07:23 PM
I plan to run a 3 battery system as wel, I have a single engine, so would have 1 battery for starting and the other 2 for stereo, as my boat already has a perko switch. I planned to start on 1 then flip to both while running so all batteries charge, then when stopped switch to 2. This way if the batteries die, I still have the 1 to start the boat. How does this system work to avoid having to do that?
ealesh33 is offline
