help scanning a thunderbolt V
Need help on finding the location to scan a mercruiser thunderbolt V 5.7 engine
I have a rinda scanner. I am use to finding the extra plug harness to plug in the scanner But these motors do not seem to have that Thanks Tom |
the plug should be close to the ECM, should have a grey cap on it, I've not hooked to a small block before
R U asking to run a diagnostic scan with Diacom for an EFI / MPI engine with a MEFI ECM & T-bolt V ignition or R U trying to scan for engine hours / RPM's (only applicable) for a carburetor app with T-bolt V ignition set up. List year and app of your engine along with what you are trying to achieve here. You did not list your exact app so that's why I am asking. Very hard to know 4 sure to give you the correct answer.
Originally Posted by BUP
(Post 4212734)
BUP- yes it is a carb. Serial 0L094899. I believe it is a 1998- Just trying to scan for total hours Thanks |
You have to hook up to the module on the distributor. there is 3 different generations of T-bolt V and there is a knock module piggy backed to it as well on some apps.. And of course the procedure is a tad different between them. Plus you have to hook to a ground... Very hard to tell and type how to do it on my end to hopefully make perfect sense 100%. I will give it shot tomorrow if all possible,.
I had figured that it was a carb app as what you were asking about but never know 100 %. There is no ECM or PCM for any CARB app marine engines. Also the Merc DDT will do the same for reading engine hours of true running time / rpms. Wonder if somehow I could get you the diacom manual. I would have to pull my out of storage or see if Diacom would send you one. Let me see what I can come up with but I will be out of town most of the week coming up if not the whole week.. |
Do you have Rinda adapter part # 94020 that connects to MerCruisers Thunderbolt V ignition module? $49.00.
If one works, Inside the Rinda technologies link below on page 54 will show you how to connect the adapter in order to read your engine hours. http://www.rinda.com/acro/merc_manual_v6.pdf If the links don't work then you'll have go to rinda technologies inc .com, find the Mercruiser marine scan tool and click on Detailed information and specifications then MerCruiser Scan Tool User Manual then go to page 54: http://www.rinda.com/marine/marine.htm#merctool http://www.rinda.com/marine/marinemenu.htm |
thanks that saved the crap out of me for typing all of that and the correct adaptors #'s. Plus it has pics as well. I am off the hook now.
Your welcome Bup. That would have been a lot of writing to do. I know you are a marine writer, but even you got to have your limits.;)
Hope the links work, I keep trying to check them but they keep coming up dead on my end.:( |
Your links work on my end.. That's why I thanked you and again THX. And you are correct to write about it would have been a lot of describing to put into words . I did have the jist about it but no indepth in my reply.
How did you know I write for a marine tech magazine ? Just asking. I do not spell very good but I have two editors from the mag go over my stories before it goes to print. Thank goodness for that. I also asked about the dot on ign. module back a month ago. I could not get a straight answer and most said they weren't sure. Like I said, years ago it was to match up to which ign. coil to use according to the color of the dot on the module. I did nt give up about asking about either for down the road |
(Post 4212825)
How did you know I write for a marine tech magazine ? Just asking. I do not spell very good but I have two editors from the mag go over my stories before it goes to print. Thank goodness for that. I also asked about the dot on ign. module back a month ago. I could not get a straight answer and most said they weren't sure. Like I said, years ago it was to match up to which ign. coil to use according to the color of the dot on the module. I did nt give up about asking about either for down the road I do have one other unusual ECM question for you to see if you were aware of this or not. The reason I'm asking is because I'm not really aware that this could be done or not even though for some reason I could foresee this being accomplished because you are able to do other things using the throttle handle on different EFI models. PS, about a month and a half ago, your private message box was to full to accept PM's . Also thanks for asking/staying with the module question. My Merc master tech friend that owns a "service only" shop is not aware of either question but keeping in mind that everyone can't know everything even though someone works with it everyday.;):) Here is the ECM question in question. http://forums.iboats.com/forum/engin...om-repair-shop |
| All times are GMT -5. The time now is 04:25 PM. |
