Go Back  Offshoreonly.com > Technical > Electronics
Speakers without an amp. >
Old 03-29-2016 | 08:26 PM
Default Speakers without an amp.
I want to install new speakers in my 242. I have 2 round speakers up front that sound really weak. I have 2 6x9s that have their own separate sealed boxes under the back seat. The rears don't work at all and the grills are rusty. I have a relatively new Sony headunit. I would like to replace the speakers with something decent. Every speaker discussion ends up with subs, amps, crossovers, tweeters, etc. I am not a big stereo nut, nor do I want to spend a ton of money. I just want to replace the speakers and run them directly off the headunit. Nothing fancy. I have been told JL audio but they seem pricey. Id like to be around $300-350 for 4 speakers.
79formula is offline
Old 03-29-2016 | 09:10 PM
ROB FREEMAN's Avatar
for 350 bucks , since you already have a head unit you can still buy somewhat cheap decent system with a cheap amp to get you some power .. 6x9 can be had for 75 bucks 6.5 same .. cheap amp / used maybe 50 bucks some 10 gauge wire ect ,, cheap rca jacks there you go .. wont be greatest but will be pretty ok .. look around a see what can be had for cheap
ROB FREEMAN is offline
Old 03-29-2016 | 09:14 PM
Does everything run off the amp? I have no idea. I have never done any stereo stuff at all.
Old 03-29-2016 | 09:18 PM
Maybe the thread should be stereos for beginners.
Old 03-30-2016 | 01:03 AM
Spending a lot of money on JL's or any higher end speaker to run off head unit power is a waste of money.
I would go with something like this http://www.ebay.com/itm/Polk-Audio-6...AAAOSwVupTqJ6d
Install them and see what you think. If you want more volume, you can still add an amp later.
Griff is offline
Old 03-30-2016 | 07:17 AM
That looks like something more my speed. That would have to be better than what I have now.
Old 03-30-2016 | 07:37 AM
Infinity or JBL are also reasonable. Like griff says run off head unit first and see.
I put a system in and rather hear the motors!
Lol
Wildman_grafix is offline
Old 03-30-2016 | 07:59 AM
Bill 3's Avatar
Seems that you need new speakers regardless. Start with that and go from there.
In my experience, you will appreciate adding an amp over the power coming out of the head unit alone.
Bill 3 is offline
Old 03-30-2016 | 08:13 AM
We only use the radio while on the hook relaxing. The boat is loud enough at cruise and my wife would not want the radio louder than the boat to hear it while moving anyways. I know their is better ways to do this. I am just looking to maximize what I have, not build a sound system. Sounds like no matter what I gotta get speakers, so I'll start there.
Old 03-30-2016 | 09:16 AM
I didn't want to put an amp in my donzi due to space. I ended up buying the blue infinity speakers with the black chrome grilles 2- 6"x9" 2- 6.5". I had them on an old Sony head unit. It would break up pretty good at about half power. I bought a Jbl gauge pod Bluetooth head unit. It goes all the way up without breaking up. The speakers sound really good with the better head unit. I would go with the infinitys. They are priced well on amazon, and as long as your head unit is decent they will sound good. I also like that the grilled is molded into the speaker so you only need 4 holes for the install
DBleil89 is offline
