Go Back  Offshoreonly.com > Technical > Electronics
Which amps for JL speakers? >
Old 04-05-2016 | 11:29 AM
Bill 3's Avatar
Originally Posted by pstorti
If you were closer I'd tell you to come hear for yourself.
The JL specs you are quoting are at 14.4v, at 12.5 it would be 250w to each sub and 180w to each 8.8, but JL has also been known to be conservative with the ratings. Also remember much easier and less expensive to install one amp vs 2 or 3 or 4. Either choice for amps will sound great.
For some reason I have always been afraid of running subs and mains off of the same amp. Different loads and power requirements.... I suppose that is the old way of thinking and the newer amps can handle it.
Bill 3 is offline
Old 04-05-2016 | 11:40 AM
F-2 Speedy's Avatar
Im doing an upgrade also, we'll rock the lake
F-2 Speedy is offline
Old 04-05-2016 | 05:18 PM
yes not a concern with any modern amp that I know of, certainly not any from JL or Wetsounds.
pstorti is offline
Old 04-05-2016 | 07:55 PM
ROB FREEMAN's Avatar
How do you have them wired 1 ohm or 4 ohm? or some other config.
4 ohm jl cant and wont let you run 1 ohm .. I'm sure you know that though .. I don't believe running 4 ohm or two ohm makes them more powerful like older amps did ,, I might be wrong but I do know jl amps arnt 1 ohm stable .
ROB FREEMAN is offline
Old 04-05-2016 | 08:17 PM
For the HD or MHD series amps they deliver the same power from 1.5-4 ohm, and same power regardless of battery voltage, which is what I don't like about them as your batteries drain they draw more and more current to maintain output.
I wasn't sure if you were running them at 1 ohm even though you aren't supposed to, but I guess no need when it delivers the same power at 4. The XD and M series though do put out more power at 2 ohms, I agree though probably asking for a short lived amp running them at 1.
pstorti is offline
Old 04-05-2016 | 08:26 PM
once the amp senses low ohm it throws it into protection mode . yes you need quality batteries . I run 4 kinetic hc 2400s . they don't fade, run till there done .I'm running two 600 /4 , and a 1200by 1 jl hds, hertz mids n highs ,
