Go Back  Offshoreonly.com > Technical > Electronics
Trim switch schematic for twin engine zero effort controls >
Old 06-28-2016 | 10:11 AM
Default Trim switch schematic for twin engine zero effort controls
Hey guys I just bought a throttle trim switch for my zero effort controls on my 87 formula 272 with twins from Great Lakes skipper and im looking for a schematic and I don't have one. I'm not sure if I didn't get them or if my girl threw them out or maybe I did lol but anyways just curious to see if anyone had one.. I would like to install the trim switch to control both outdrives and also keep my independent switches for each drive and I feel if I tap into the switches it will back feed and I will not be able to control each motor independently. Any help would be great!
keithp83 is offline
Old 06-29-2016 | 02:19 PM
You will need (4) diodes, install between your single trim switch and your individual trim switches. A diode works like a check valve, the current can go one way but not the other. I believe there is a good diagram on Livorsi's website.
topgas is offline
Old 06-29-2016 | 02:22 PM
what topgas said...
Jims406rs is offline
Old 06-29-2016 | 03:46 PM
thanks! im having trouble finding the diagram, you wouldn't happen to have the link would you?
keithp83 is offline
Old 06-30-2016 | 07:53 PM
Just looking for that myself. The schematic is on the last page http://www.livorsi.com/pdf/th_series.pdf
Propster is offline
Old 06-30-2016 | 08:11 PM
mercury sells the twin motor diode assemblies
are color coded and plug and play
I got mine from marine engines .com
need 2 1 up and 1 for down
johnmiffco is offline
Old 07-01-2016 | 08:11 AM
how many amp diode will I need? im assuming not much since im running to a relay and not the actual motor
keithp83 is offline
Old 07-01-2016 | 08:38 AM
is this a clamp on style I been looking for one for a while can u relay the part number thanks
VETTESPINNER is offline
Old 07-01-2016 | 09:42 AM
http://www.ebay.com/itm/Baja-Formula...FXdUVC&vxp=mtr
this is the exact one I bought
keithp83 is offline
Old 07-01-2016 | 02:29 PM
Thanks looks like it will work for me Thanks again
