NMEA 2000 and simrad GO7 questions (not good with electronics!!)
Most boats are made from plywood, then fiber glass, then gelcoat. A sounder cannot transmit thru air, so if there is a void (air between layers) the sounder will not work. The sounder will transmit thru a solid hull. and while I'm not positive how an active thunder is made, I'm pretty sure you should not have an issue
From what I'm finding the nema drop and back bone cables are the same. Issues with nema is distance and voltage drop. A .5 M cable isn't much but the connector would be the only item I would thing of. When you remove the cable does the fault go away?
Edit: should mention no cable length shall exceed 20 feet (6 M)
