Gauge replacement
Have several gauges needing to be replaced in my 28 Donzi zxo and was considering a new panel and vessel view instead. Thoughts?
Not sure how much room you have on your dash or if its a flat dash but this is what I use on my Cruisers 500 express.
https://buy.garmin.com/en-US/US/p/169212 I dont know if you would need a converter box or not but with this you can have any gauge on the screen that your motor outputs info for. Also you have your gps on the same panel. I think you can even do split screen but I have never tried it as I am running 2 of these. Seems like over kill but the previous owner had it set up this way when I bought it. Simrad has a similar version that I think looks even nicer. Chris |
[QUOTE=Blueabyss;4557557]Not sure how much room you have on your dash or if its a flat dash but this is what I use on my Cruisers 500 express.
[url]https://buy.garmin.com/en Thanks Chris! pick looks awesome and kinda what I had in mind for mine. I just don't know the different brands or pros/cons with them. |
| All times are GMT -5. The time now is 04:10 PM. |
