-   Electronics (https://www.offshoreonly.com/forums/electronics-291/)
-   -   Mercury 525 trim tab help (https://www.offshoreonly.com/forums/electronics/347456-mercury-525-trim-tab-help.html)
IGetWet 06-06-2017 05:16 PM
I need help getting my trim tabs to display on my Simrad GO9. Livorsi tabs with electronic senders wired to engine, engine smartcraft cable to vessel view link, vvl to nmea 2000 network and then to Simrad. Everything else from the engine displays just fine. The testing I've done suggests the signal is getting to the engine but is stopping there. Any help is appreciated.
30outlaw 02-21-2019 07:29 AM
ever get this figured out?
IGetWet 02-21-2019 08:05 AM
From what I’ve been suggested from Eddie Young and Dustin Whipple is that the firmware version of my motor probably doesn’t support the trim tab function. The motor I have is an earlier model 525, so that’s probably the issue. I really don’t need a tab indicator, go off of feel, but I’ll probably add a Livorsi LED indicator at some point.
VoodooRob 02-21-2019 08:53 AM
IGetWet Were you able to get the trim from drive to show up on the Simrad?
IGetWet 02-21-2019 09:04 AM
No. Seems the motor PCM firmware version doesn’t support the trim tab function. I even got the pin out of the PCM from mercury support and was able to confirm the signal from the tabs is going into the pcm.
VoodooRob 02-21-2019 09:32 AM
My drives are not showing on my G05s. I talked to Mike at MDC thru email and he gave me some tips to try and if that doesnt work he can work some magic and get a signal from the Trim Sync I installed.
IGetWet 02-21-2019 09:37 AM
Shoot, sorry misread your first post. Yes my drive trim displays on my simrad no problem.
F-2 Speedy 02-21-2019 09:52 AM
Mercury cant reflash the controller with updated firmware that will support it ? we do it all the time in my world
IGetWet 02-21-2019 10:51 AM
Not a computer that’s been reprogrammed by Whipple or any other aftermarket shop. Mercury has never came out and said anything about the firmware upgrade, so I think they’re trying to keep it under the rug.
F-2 Speedy 02-21-2019 11:00 AM
ya , I forgot it was whippled
Brembofreak 02-22-2019 01:24 PM
A friend have 2x 525 sci and ad 2 smartcraft trimsensors to the tabs,connect them with Y cable to plug on the motor and see them in the smartcraft!
My 600 SCi have same plug and i am shure the tabs will be see when i add senders on them.
Michael
