Amp mounting suggestions
i am planning an upgrade in my Sunsation 28.8 MCOB. Need suggestions on amp placement, I have 2 amps I need to install. Any suggestions? I was thinking somewhere in the cabin may be best. They are marine amps but the mfg does not suggest you install them in the engine compartment.
Of all my stereos I have added to boats I always do them in the console. But I have never had a cabin. I agree , not in the engine compartment .
I would avoid putting it in the engine compartment due to the wet/moist/hot environment. Try putting it under the dash, the closer to the head unit the better, as you will be able to run shorter RCA cables (with longer cables running next to power wires there is more probability of introducing interference).
With the amp in the dash, it will be far from the batteries, so just make sure you use a very high quality and proper gauge power and ground to the amp. |
Originally Posted by TorchLK
(Post 4606683)
1 Attachment(s)
I mounted mine in the cabin. It’s surprising how hot those puppies get! Little bit of a pain with more cable mounting them further from the batteries but I think they’re safer here. A little paint and some creativity with my wife’s vinyl cuttter and viola
Attachment 574662 |
Installed mine under the bench seat. Location still allows for plenty of storage. Shortened up the battery cable runs significantly and don’t think they will get too hot. Rubber mounted to reduce vibration. https://cimg1.ibsrv.net/gimg/www.off...34612c626.jpeg https://cimg2.ibsrv.net/gimg/www.off...1446b3fe0.jpeg |
The above install is a clean and great option. The only thing I would suggest, is to use a good high quality tinned power wire.... To prevent corrosion. |
| All times are GMT -5. The time now is 11:12 PM. |
