-   Electronics (https://www.offshoreonly.com/forums/electronics-291/)
-   -   Garmin 720s - Livorsi Speedometer (https://www.offshoreonly.com/forums/electronics/363686-garmin-720s-livorsi-speedometer.html)
Markus 06-06-2024 01:04 PM
I doubt you can make it work.
NMEA0183 is a mess.
See the thread I created about hooking up a newer Garmin GPS to Mercury Smartcraft.
F-2 Speedy 06-06-2024 01:17 PM
Originally Posted by wieland77 (Post 4899854)
Curious if anyone has any advice for my wiring. I have a Garmin 741 XS and a Livorsi GPS speedo, Garmin works great but cant get the speedo to work. I have the blue wire from the Garmin hooked to the white wire from the speedo and when turning the GPS on the speedo cycles, goes to the 9 oclock position and after GPS signal is required speedo goes to zero or jumps to around 4 mph and will not read speed? I do not see where i can change the output settings on the GPS, I have the same setup as this thread starter and do not see a solution in this string. Anybody know what I'm doing wrong?
I have the same Garman 741xs and mine doesn't work ether, hope we get an answer
techman 06-06-2024 01:22 PM
Are you dealing with the Livorsi antenna that died because of the non-replaceable battery?
If so, just remove it and replace it with this:
F-2 Speedy 06-06-2024 01:42 PM
wieland, does the back of your speedo look like this ? which white wire are you using
https://cimg7.ibsrv.net/gimg/www.off...a6fcd98252.jpg
wieland77 06-06-2024 02:31 PM
Yes, exactly. I had an older Garmin GPS 180 that I had prior hooked to the speedo and it worked perfectly. The new 741 XS i wired the same way, blue wire from Garmin to white wire from speedo and it doesn't work.
F-2 Speedy 06-06-2024 02:36 PM
My old one was a 180 also, are you using the white wire in the big plug or the single small one........
wieland77 06-06-2024 02:38 PM
the single small one you have labeled PRT
F-2 Speedy 06-06-2024 03:11 PM
ok thats the way Im connected, I did go into settings and turned on 2 other perimeters that were off
Markus 07-05-2024 12:40 PM
Again, the NMEA0183 standard has changed several times in the 25 years since the GPS Map 180 was introduced. Newer Garmin devices are most likely not compatible with a turn of the century GPS speedometer.
Get an NMEA2000 speedometer.
