Go Back  Offshoreonly.com > Technical > Electronics
electric push button switches >
Old 10-02-2020 | 06:38 PM
Originally Posted by ph1971
The Blue Water switches are 15 amp max. A starter relay should solve your issue.
Yea, that’s what the solenoid on a starter is for...
IGetWet is offline
Old 10-02-2020 | 06:54 PM
The starter relay is already there, its called the slave relay, he needs a main power relay (Red/Purple to Purple) connection
Many of the cruisers place a key switch inside the cabin which sends power to the helm. My self I like the hidden kill switch, and I would place it on the Red/Purple (main power feed)
AllDodge is offline
Old 10-04-2020 | 09:15 PM
Originally Posted by IGetWet
The purple should be energized when the ignition switch is operated. The yellow/red should be energized when the start switch is energized, operating the starter solenoid, that’s a 16ga wire max and I can’t see that drawing more than 15A. Those are the blue water switches correct? It’s either wiring in the boat or bad switches or the design of the switch. Maybe you could try one for a start switch on another boat. Start only not ignition and start.
correct blue water https://www.bluewatergadgets.com/ the 22mm electric switches.
Originally Posted by Baja Rooster
For those of you using the start buttons are you still using a key elsewhere?
no, just the main battery switches.
30outlaw is offline
Old 10-06-2020 | 08:59 AM
MikeScarab28XLT's Avatar
I use the Mercruiser Ouick Stop Switch for ignition on and a Start Switch from ebay. Works fine on my 525efi`s.
MikeScarab28XLT is offline
