-   Electronics (https://www.offshoreonly.com/forums/electronics-291/)
-   -   Dash mounted warning lights (https://www.offshoreonly.com/forums/electronics/378551-dash-mounted-warning-lights.html)
PQ290Enticer 03-03-2023 01:52 PM
In another thread I had someone comment that they had the warning buzzers for misc. things like low oil pressure or high water temp but also had some dash mounted lights that would also come on. I'm thinking about adding them but wonder what type of sensor is used to turn the light on? It seemed like overkill but the more I think about it the more I like it. With the wind noise and the stereo I might not hear the buzzer but I might see a light on the dash. Thanks for your help.
boostbros 03-03-2023 03:01 PM
red low oil pressure light saved us when an oil fitting broke you can not hear the warning buzzer when running hard
PQ290Enticer 03-03-2023 03:03 PM
Is there a "Kit" I can buy?
TomZ 03-03-2023 03:54 PM
Not really. If you have an warning buzzer, you can tie a LED lamp into the same circuit.
Griff 03-03-2023 11:05 PM
I just installed some red warning lights in my dash last year. All you need to do is splice the wires from the warning light into the factory merc alarm buzzers.
https://www.sbmar.com/articles/basic...iring-example/
Markus 03-04-2023 01:14 AM
Warning light
I had a red warning light connected to the buzzer circuit in a boat. Very useful.
For SmartCraft-compatible engines, Mercury sells a 7-way alarm gauge. I have never seen one in real life, so I don’t know if it shows a strong light when an alarm goes off.
PQ290Enticer 03-04-2023 08:44 AM
Thanks for everyone's comments. Griff, Thanks for the wiring link. It does look easy enough.
Mbam 03-05-2023 08:32 AM
Back in the day I had back-up alarms instead of buzzers. I also had a strobe in addition to normal warning lights.
I learned the hard way how hard it was to get my attention when running hard. Open headers, wind noise and concentrating on driving all compete for your attention.
DrFeelgood 03-05-2023 08:35 AM
Since we're having this discussion, is there a list of the circumstances where the stock MEFI-1 would actually sound the buzzer (502 Mag MPIs)?
Griff 03-06-2023 01:58 AM
Low Oil Pressure
High Water Temp
Low Drive Lube
