Go Back  Offshoreonly.com > Technical > Electronics
Anyone use Holley Sniper EF on their 454/502 ? >
Old 09-28-2023 | 09:42 AM
I`ve had 2 HP ECUs/ Dual syncs without issue for a while now and they get their ass beat on lake Michigan.
My belief is a lot of Issues are related to electrical interference.
I use thse in different sizes and put em all over
Amazon Amazon
Also resistor plugs vs non resistor.
ICDEDPPL is online now
Old 09-28-2023 | 10:48 AM
articfriends's Avatar
[QUOTE=ICDEDPPL;4881209]I`ve had 2 HP ECUs/ Dual syncs without issue for a while now and they get their ass beat on lake Michigan.
Amazon Amazon
I just went thru and fixed all the damage from oil lines being backwards, oil cooler having shipping caps still in cooler fittings, you name it on a 548 a guy shipped from texas that was ran for 4 hours.Had a holley terminator and dual sync, if you changed timing from 32 to 34 it picked up slight power, if you changed timing from 34 to 36, it lost 60+ hp. changed caps, wires, ignition box, coil, re synced dist at 50, set base timing, rerouted wires, checked timing at 3000, 4000, 5 etc to check inductance dwell. Exact same results. Threw a msd ready to run in it, fired injectors only, was fine, reinstalled his new looking dual sync in again, same exact issue. Borrowed a customers dual sync, poof, ran fine even at 36, defied logic. Ordered him a new one, ran fine, engine dropped 6 hp with the substitutes and the msd at 36 vs 34, 34.5 which is expected BUT did not plunge. It also had a slight breakup/slight miss with the original dual sync
articfriends is offline
Old 09-28-2023 | 08:25 PM
Rookie's Avatar
So, it was the dual sync. I'm going to switch mine and see if that is where my lost 400 RPM's are.
Rookie is offline
Old 09-29-2023 | 06:53 AM
Yep, it completely defies logic but heres yet another dyno session that tuned into multiple extra days Ill never get paid for because of these
Chinese built parts/. Theres also NO replacement module or main pieces for a dual sync aside from cap, rotor etc
