Go Back  Offshoreonly.com > Technical > Electronics
Fusion Head Unit Connectivity Issues >
Old 12-28-2024 | 09:19 AM
Default Fusion Head Unit Connectivity Issues
I have a Fusion head unit with 2 JL Amps and 12 JL speakers that I've never had an issue with until last weekend, where it suddenly started to connect/disconnect quickly with my phone. I powered both the phone and the head unit off/on, but nothing seems to work.
Anyone else have this issue, and if so, what was the solution? Thanks
speedE55 is offline
Old 12-28-2024 | 11:37 AM
have u tried going into ur phone settings and deleting the fusion bluetooth device connection
then turn on radio and have phone make a new connection
have had to do that before to get phone back connected for tunes
johnmiffco is offline
Old 12-28-2024 | 11:50 AM
Sydwayz's Avatar
Forum Regulator
Veteran: Air Force
1) Try with a new/different/friend's/spouse's phone.
2) Do you have the Fusion App on your phone and is that tied to the head unit? Sometimes that makes things a little more stable.
3) Not Fusion, but the Retrosound I have in my classic Lincoln started doing the same thing. I eventually just had to replace it.
Sydwayz is offline
Old 12-28-2024 | 12:01 PM
I haven’t completely removed the device from my phone but I’ll try that thanks
speedE55 is offline
Old 12-28-2024 | 12:04 PM
F-2 Speedy's Avatar
Are you using BT for connection ?
F-2 Speedy is offline
Old 12-28-2024 | 12:05 PM
yes, that’s the issue I’m having is with the BT
speedE55 is offline
Old 12-28-2024 | 12:07 PM
F-2 Speedy's Avatar
You might check to see if there is a new software update for your phone
Old 12-28-2024 | 02:29 PM
Or if you have the Fusion app there may be a update for your headunit
jwill is offline
