can i see some 28 tall decks?
The main reason for the speed difference in newer vs. older boats is X-Dimension. As far as I know the bottom is identical on all 28's tall decks, low profile, and ICC. the difference is the deck mold only. Oh and you want to see some pics mine is in the classifieds.
The 28 ICC has the 28 Lp bottom under it. The 28 standard deck was a little slower then the 28 Lp bottom with twins. That is why Bob went with the 28 Lp bottom under the 28 ICC. Although we just built a new 28 tall deck and sold it to a customer in SC and with only 700Hp a side it ran 134MPh. The X- dimension is higher now then it was years ago, that helps alot. Hey Dave you get any hits on your 28 ICC? If not I think I have a customer for it. I will give you a buzz later. Preston
Did you get to experience some Real Rough Water in the 30?
That trip up past the toll bridge got rough really quick.
Engines, dirty bilge and back of dash
plenty of boat for your needs
