Shueman?
Do you know generally what speeds the eagle 25 hull will start to chine walk at? I know it varies greatly, but mine is a factory rigged install, so i'm sure it was done right..Will the tabs truly help or is it just gonna be unstable around 80? Design limitation?
Thanks!! |
Originally Posted by okeagle25
(Post 2541514)
Thanks!! |
85-90 ours started to chine top speed was 108mph was alot to handle.You need to learn to balance it if you look at the rear of the boat it sits on a 5 inch flat pad and at speeds you blalance it there.
Cool
Thanks for the info. I cant imagine an eagle running 105, it would HAVE to be squirrely as heck!!
I'm gonna check my steering over really close, I think it might have some play in it. I have the dual ram add on, and there is a little delay in it, plus I think the steering effort is too high i think. |
If you are approaching those speeds you defiantey need full hydro to the helm.
| All times are GMT -5. The time now is 06:51 AM. |
