-   Eliminator (https://www.offshoreonly.com/forums/eliminator-35/)
-   -   140 in older Daytona 33? (https://www.offshoreonly.com/forums/eliminator/200671-140-older-daytona-33-a.html)
RunninHotRacing163.1 01-28-2009 06:55 PM
Originally Posted by Adrenaline Junkie (Post 2767029)
RunningHOT -if your'e referring to me - my 36 came to me with the tab - and yes I do use it.
NOPE Adrenaline was refering to Scott Stormbauer and the monster tab hes installing ...and yes we used ours also or the chit in the cabin would end up on the back seat the porpousing mofo :cool-smiley-027:
RunninHotRacing163.1 01-28-2009 07:02 PM
Originally Posted by B BOATER (Post 2787556)
FYI Runnin hot new 33's dont have an air tab nor do they need one. Noticed that you love to bash Eliminator as much as possible. no popoise 139mph 700 mercs. not saying there wasnt a porpoise problem to begin with but the hulls have changed since you had your issue.
a porpoise problem to begin with .... I would say so BIG Daddy even after pulling the motors, & 2 trips back to the factory in mira loma to roll it over and redo the bottom and add the inserts Thane designed still a porpouise MOFO ... even with Brent L on the sticks brought it back to the dock at Elsinore and shook his head :ernaehrung004::ernaehrung004:
22% slip was phuchin pathetic man :cool-smiley-026:
Not bashin bro tellin it like it is , and everything was suppose to be taken care of but the shipping instead things changed ..
RunninHotRacing163.1 01-28-2009 07:05 PM
no popoise 139mph 700 mercs!!!!!! cool
sounds like you got her all dialed in what rpm,ratio,prop ????
:ernaehrung004:
B BOATER 02-02-2009 12:51 PM
1.35 gear 40 pitch 5400 on the revlimiter. Runs 131 with the 39s alot better midrange 6 guys. Props are Merc. CNC 39x21r x 16.25 135mph and 40x18Rx16.50 141mph. The 40s handle strange and wont get on plain with a full load so we run the 39 most of the time.
B BOATER 02-02-2009 12:59 PM
I have heard that Tony was going to try another hull with 1.24 gear for better top because we are having problems finding big enough props that we can still get on plain with.
