my first cat
I agree with jdnca1 on the props. His boat is very similiar to mine except that he has more power, more weight in the back and I have a windshield.
With that power, you should be ~105. I don't run labbed props becasue I have cracked a couple of regular Bravos and think the labbed props would crack easier.
I think you could run 30" or 32" Bravo Ones.
However, I threw blades on 2 separate occassions with labbed maximus on my 36 w/625 Ilmor's...all within about 25 hours of use. Since going back to 4 blade stock props on my 36, I lost mid range, and some top end...but haven't thrown a blade in 40 hours of use (knock on wood).
So, I would concur...the higher your xdim and the more HP you have in front of a prop will increase the probability of a blade being thrown on a lab prop...more so than a stock prop.
I had to prioritize - running issue free became more important to me than a faster cruise speed and a bit more top end.
But that was my priority...and may not be consistent with others.
If you turn a 30 4 blade ~5600 you will be ~102...that's what mine ran with 500EFI's stock except the rev limiters were bumped up..it got there pretty quick too. I have boxes, and then ran std. length lowers. No planing issues at all.
The ONLY reason to run a 5 blade on a 28 Daytona IMO is if you can't get on plane with a 4, are out of gear, or want to cruise ~10mph faster at the same rpm...you will loose whack (acceleration) every time when you go to more blades on this boat. I have never tried a maximus, but have spoken to several who have...I havn't found anyone that was happy with them on a 28....
I have significantly more power now and still run labbed 33 bravo's, just went to a 1.21 gear to make them work.
Hey Chip, I have a 36 daytona, and I go to Grand sometimes. We go to Tenkiller alot also. Here's a picture so if you see us come on over and get aqquainted. Here's a Picture--Your Eliminator looks good.
Cory, the boat looks good--take care of my Baby----
I have 4 blade 30's with 496 ho's on my 30. I couldnt imagine trying to spin 32 5 blades. didnt realize a 28 was that much lighter than a 30.
