Prop rotation on twin 30 eagle
Has anyone tried spinning in on a 30 eagle . I have a 01 30 eagle twin 500 efi 1.50 xz drives the boat runs 93 know with stock 30 bravos at 5250 rpm i have also run a set of stock 32 bravos and get 90.5 at 4900 rpm I'm not sure on x dimension at the nose cones it's 3" below the hull but 1" above the keel pad I believe this is the same eagle that came from hawkeye marine in 01 or 02 mine spin out know i know its easy to swap props around to try I was just looking to see if anyone had done it and maybe get their input on it about the handling and chine walking before i mess with mine Thanks for any input
