-   Eliminator (https://www.offshoreonly.com/forums/eliminator-35/)
-   -   X dimension ??? (https://www.offshoreonly.com/forums/eliminator/325771-x-dimension.html)
ROMO2233 05-01-2015 02:34 PM
X dimension ???
I have a 30 daytona with twin 525 the bullet of the outdrive is about a half inch under the bottom of the boat. Where should it be, i was told any where from 2 inches under to 4 inches over?? i am looking for top speed. I am hoping for around 110 mph. Thanks
Tinkerer 05-02-2015 09:35 AM
With twins you can be higher than with a single. I have a 26 and am at 1 inch above the lowest part of the hull. ( about 12 inches forward of the transom ) I am installing an IMCO neutral extension box and I am raising it another inch. I did have to modify the drive for more negative trim to get on plane but my slip numbers are 11% at top end and it doesn't blow out when turning with the drive set to neutral. That is with a 4 blade prop.
I would try some -2 shorty's
If you are near Grand Rapids MI I have one -2 and one -3 shorty if you can find another.
Steve
dsmawd350 06-16-2015 08:51 PM
Curious to see how yours goes tinkerer. I am also 1" abover the lowest part of the sponsons before the notch. But I am out on a box. I'd like to see how you do on a 12" box 2" above the bottom
rob vanharten 10-03-2015 04:38 PM
I have just purchased a 99 28 tall deck with twins , and I am about 3/4 of an inch below the bottom. I am thinking some -2's would pick up some decent speed. Do you still have these lowers?
