Cool looking ride, check with Raymond Robert @ Double RR Performance the boats I have seen come from him and his painter look really good. Good luck with your Cat.
In the water for 2007
:party-smiley-048:
Here are some in the water pics. Still a lot of work to do but at least we are boating. http://i139.photobucket.com/albums/q...1/IMG_0657.jpg http://i139.photobucket.com/albums/q...1/IMG_0643.jpg http://i139.photobucket.com/albums/q...1/IMG_0645.jpg |
looks great!! What kind of numbers? Looks like a boat load.
I don't know what the top end is yet but we are doing 71-72 in the pictures. This is only the third time I have had it out and I am still learning to drive (trim angle, rpm,3ft chop,etc).
It does like large chop though, I had it airborn at 50mph running with the waves this weekend and yes we did get wet but had lots of fun. :D |
I had a Active cat with KAAMA drives, they sound soo COOL, and I never had a problem with them.
Active cat with kammas top speed
What kind of engines did you have .What gearing,props and finally
what was your average top speed. I am running 1.53 ratio 502 tranys with 13% overdrive with 23 pitch props X 17 inch diameter and I hit the rev limiters at 6000 . My engines are 454 ls6s with 10 to 1 compression rollerized,gill manifolds with dry exhaust been modified to look wet.(noise rules). I have just installed 27 pitch X17.5 props but haven't had it in the water to test yet. :boat: |
Good looking with the stripes.
Does anybody know. What the Hull was capable speed. Wise. Safely |
If you were hitting the. Revlimiters you were way under.proper
You could. Gain 10mph. Or. More |
| All times are GMT -5. The time now is 02:44 PM. |
