best sealent and paint
i am in the process of removing the silent thunder box from my formula and replacing it with some cmi mufflers. between old bracket holes and new holes for the mufflers there are a number of thru transom holes. what is the best sealent or paint to use to prevent water damage to the core plywood of the transom?
also when i bolt up the mufflers what is the best sealent to use around the flange?
thanks
thanks
Re: best sealent and paint
use west systems epoxy on any exposed wood in the thru holes and 3M's 5200 to seal any thru hull fittings.
08 OPA High Points Champion
'nuff said
