Bottom Paint
Old 04-15-2006, 11:14 PM
Default Bottom Paint
Bought boat wh/ was coated with Anti-foul on bottom, as in water full time during boat season. Will have in dry storage, so am looking at options. I like the black on bottom of boat, but do not like rough texture, or fact that it tends to slow boat. Any thoughts / recommendations appreciated.
johnsc91 is offline
Old 04-22-2006, 12:25 PM
Default Re: Bottom Paint
If you want to keep the bottom paint on, but want to streamline it, it can be sanded smooth and if you don't cut through, leave like that and wax.
If you cut through, repaint with Interlux High Performance bottom paint (it can be sprayed slick) and may pick up a MPH!
Sand off all the paint an recoat with Awl Grip to match gel or black.
Gmoney52 is offline
Old 04-24-2006, 10:54 AM
I thought awlgrip could not be used below the waterline?
srracer is offline
Old 04-24-2006, 11:07 AM
The literature doesn't reccomend it, but if it isn't going to soak for extended periods, I personally haven't had problems. Prep is key and my bottoms have passed the 100+ MPH test. I'm sure others will say the same thing, eh?
Gmoney52 is offline
Old 04-24-2006, 10:16 PM
Catagory5's Avatar
Once you sand a full bottom full of old bottom paint you will never want to do it again. Just throw away your clothes and maybe you won't be tasting it all week.
Catagory5 is offline
Magicfloat
01-12-2008 01:07 PM
Nykamp
Fiberglass and Paint
6
04-16-2007 01:55 PM
JLaufer
5
03-14-2005 11:27 AM
CAP071
12
06-08-2003 10:48 PM
The Raven
08-25-2002 11:57 PM
Quick Reply: Bottom Paint
