Which caulk?
Which caulk?
I'm installing my windscreen (fairing) after removing it for some winter work. It's screwed in but I need to caulk where it meets the deck. When I removed it getting the old sealant off was a *****. What's a good sealant (white) that won't discolor, won't crack and still be able to be removed relatively easy? Taking off the fairing is the only way to get to the guage wiring so I need to think ahead in the event it needs to come off again.
Re: Which caulk?
if you need something that is still serviceable just use a good whits or clear silicone
08 OPA High Points Champion
