Go Back  Offshoreonly.com > Technical > Fiberglass and Paint
Wet sanding Allgrip >
Wet sanding Allgrip
Wet sanding Allgrip
Old 06-30-2006, 07:37 AM
  #31
Zanie's Avatar
Default Re: Wet sanding Allgrip
Cool,
I bought the awlgrip wax, I'll need to get the boatwash.
Thanks!
Dan
Zanie is offline
Old 06-30-2006, 08:14 AM
  #32
madbouyz's Avatar
I've seen the Awlgrip wax before but never used it. Can someone explain if it is really a wax in the sense that you put it on and then buff it off ?
I'm sure that I've seen it described as some sort of 'polymer treatment' that leads me to think you just wipe it on like Armourall...
madbouyz is offline
Old 07-01-2006, 07:30 PM
  #33
Scroll down near the bottom of this link and check out the Hutchins 7544 Water Bug III:
http://www.smartshoppersinc.com/Hutchins/hutchins.html
ajs67Donzi is offline
Old 07-10-2006, 09:09 PM
  #34
I agree with Dave about the machine sand vs water because a grit of dirt will do lots of damage and the time savings are worth the cost. I haven't seen AwlGrip repaired perfectly in a dark color, but AwlCraft is easier to work with. The last I will say is if you want to buff AwlGrip, clear coat it and do it within 48 hours. After that , don't do it! I personally will chose another paint before I would buff out any US Paints, they are made to use as painted.
Gmoney52 is offline
Old 07-11-2006, 04:02 AM
  #35
vandeano's Avatar
You apply the wax like any other wax. I apply it by hand and then when it dries to a haze, I polish it off by hand. On the container it mentions it is to be applied by hand only no machine. I have used a machine polisher before to remove the wax and had no problems. I just would'nt wait to long after it dries to a haze because it can be a pain in the ass to remove. That is when I used a machine.
vandeano is offline
Old 07-11-2006, 06:54 AM
  #36
madbouyz's Avatar
Thanks for that.
I may end up trying it out in the not too distant future !
madbouyz is offline
marineclean
73
09-21-2009 01:37 AM
David Stotz
11
05-21-2007 03:39 PM
pol98xc6
5
02-18-2007 04:07 PM
US1 Fountain
8
03-19-2004 11:20 PM
puder
23
06-04-2003 03:54 PM
Quick Reply: Wet sanding Allgrip
