Best Paint?
Old 09-11-2006, 01:46 AM
Excalibur Dude's Avatar
Default Re: Best Paint?
Hey Cuda,
Looks like you have the same sprayer I do and are doing about what level a paint job I want to do to my 1978 jet boat. Did you have to thin that paint out to get it to spray good. how come you rolled the bottom?
thanks for the info!
Excalibur Dude is offline
Old 09-11-2006, 08:21 AM
cuda's Avatar
Yes, I thinned the paint a little. I rolled the bottom just because it was easier. That paint flattens itself amazingly well.
cuda is offline
Old 09-11-2006, 09:31 AM
Cool, what did you reduce it with?
Old 09-13-2006, 06:42 PM
cuda's Avatar
I reduced it with the reducer they sell for it. I also ran out of it, and reduced it with paint thinner. I couldn't tell the difference.
cuda is offline
Old 09-13-2006, 07:32 PM
cool, this will be the project boat.
Old 09-18-2006, 11:05 AM
mr_velocity's Avatar
I went the PPG route as recommended with Glassdave. Job turned out really good once Glassdave saved my butt. He is the man when it comes to this stuff.
mr_velocity is offline
Old 09-19-2006, 08:15 PM
Not following what that means....more info please???
Old 09-20-2006, 12:17 PM
I'm by no means a painter, had a little problem with the gun pressure so orange peel was a problem. Glassdave gave me some advise to get the gun setup properly and get the peel out. The ppg route is PPG DP Epoxy Primer, Deltron 2000DBC base and Concept 2021 or 2002 clear.
I have also sprayed the interlux stuff quite a bit, you use 213 reducer if spraying and 333 if brushing. The 333 doesn't evaporate as quickly so the paint hs a chance to lay out flat. Cuda if you think that stuff worked well, wait to you try their Perfection paint, its a 2 part that you need to apply over their epoxy primer. Thinners are 2333 and 2213N if memory serves me correctly. Its good stuff and I find it very easy to use.
Old 09-20-2006, 05:13 PM
cuda's Avatar
I hope my boat painting days are behind me. I enjoyed painting, but the prep sucks! I can't do glass work worth a damn. I work, and work, and work at it. Looks fine when primed, but as soon as you shoot the shiny stuff on it, my glass works sticks out like a sore thumb.
cuda is offline
Old 09-20-2006, 05:37 PM
Thanks for the info Mr. Velocity
SLINGSHOT
Fiberglass and Paint
8
09-06-2011 08:10 AM
wwwTOPDJcom
2
03-06-2003 10:36 AM
Quick Reply: Best Paint?
