question on repairing crack in the michelob lights deck, & resto pics
3 Attachment(s)
the deck popped in the argentina race and has rebroken and been re repaired a few times. i was planning on fitting 3 peices of oak or spruce with the grain running for and aft, that i will expoxy to the underside of the damaged area then repair the exterior with epoxy and fiberglass. it had 2 alum plates they used to fish plate the damaged area from the outside, i plan on using epoxy to reinstall the plates after the exterior fiberglass work is finished. what are your thoughts? keep in mind its cracked thru on the top of the upper lip the side of the raised area and thru the flat area of the deck itself. i plan in running the boat had in big water so want to do the strongest repair possible. thx for your input. rm
Re: question on repairing crack in the michelob lights deck, & resto pics
3 Attachment(s)
more pics
1 Attachment(s)
tear from the st pete race spinout :eek:
Battle Scars..........
Looks like you've got a project on your hands!!
Is the Deck/Hull glassed together? If not, it may be good piece of mind to glass it while you're at it! :cool: |
Originally Posted by ratman
the only problem area is the cracks pictured at the engine compartment bulkhead and deck. im wondering the best way ot reinforce this area. from the underside as its eveidently i highly stressed area. thx for any suggestions to the metodology of repairs. rm
As for the side of the boat, it probably cracked when the hul flexed against the bulkhead. Did the bulkhead pull away from the side of the boat on the inside? To keep this from happening again, I've seen glassers make a 45* radius at the corners of the bulkhead so it's not a sharp 90* turn. I wish I had a picture to post to show what I mean cause it's hard to explain. On the outside I would also grind out the cracked section at least 6-8 inches outside the crack, then fill it in with triaxial and epoxy, then gelcoat overtop. Again, from my limited experience with fiberglass and boats this is what I would start with. There may be a better way and hopefully an expert will chime in here. :cool: |
I agree with Panther's previous post but as for your idea of putting spruce or oak under the deck, I personally would not do that. You have to think of the physics involved; dissimilar materials flex at diferent rates. Something very rigid like oak is going to tend to split away from the fiberglass on the deck, because the deck flexes by it's design (as opposed to the transom which is basically fixed). I would sandwich Klegecell between layers of bi-axial and tri-axial. Being a foam core, the Klegecell will form well, give strength, and be flexible as well. This worked well on my old Top Gun and my old Coyote raceboat. You can get Klegecell from Fiberglass coating in St. Pete. 1-813-327-8117.
Barry |
:eek: :eek: :eek: :eek: :snide: :hothead:
Originally Posted by Papache
maybe you can return and get your money back???
I'm sure others will chime in but I'd repair it with Epoxy as well. Couple layers of Biaxial or Triaxial on top, then multiple layers underneath. If you have access underneath I would also see if a stringer can be glassed in place.
Barry |
Make sure you grind the craks back from the outside and do the repair from the outside then do reinforcing on the inside. Epoxy is great but remember it could screw you if you plan to use polyester paint/gel on top.
Jon |
just sink that barge, it will be better for all of us... :evilb: :evilb:
Jon |
thx barry i'll give them a call
with talk like that i will find you in a week! you 609'er you... :evilb: :evilb: :drink:
i plan on using ppg k36 primer, and awlgrip snow white for the paint.
Rat, a roll of duct tape, couple tubes of super glue and your back in bus!!!!! Good luck w/ your project! Wrink
Barry |
barry what is the purpose of using the klegecell instead of just tri or biaxial cloth and epoxy? btw st pete is a 727 area code, talked to wood down there at spfc nice guy. i just email him some pics of the damage. thx, again. rm
http://www.noahsmarine.com/Canada/Co...group-can.html |
Cool project !!!!! thx for the pictures. That is one of my all-time favorite boats. Saw that boat race in Saugatuck when I was 16. Really nice to see somebody fixing it up. Good Luck, I'm sure its going to be really nice when its done :)
I fully agree sink it. :drink: :drink: |
Originally Posted by Ike
What a ass!!! :mad: :rolleyes: :rolleyes:
He's just a Piney! He runs he boat down in Bricktuckey! :D
only reason i dont have you killed for that slander is your sister... mahser likes to keep her around.. you know, we sell her to the locals for cases of beer, then break her out for the trip home...... :evilb: :evilb: |
You going to Strong Island to play with the motor boats this weekend? I can't make it but I'll be sippin Rum Runners by the pool in Marathon starting tomorrow! :drink: |
no i have to be with the family.... :evilb: :evilb: lake george is my last event this year with the boys....
Rat - it doesn't look that bad to me, and I know you have a very short timeframe in mind.
The hull cracks look (at least from the pics..) like they were repaired pretty well, looks like they only showed up after sanding the hull for paint. The damage you're worried about... Oak, or Spruce????? Come'on man, are you building Noah's ark out of that thing?? Wood is goning to split in that boat (the way you run :D :drink:) long before you have to worry about rot. Don't cheap out/hurry/F-yourself because you want it done as quickly as you do. This ain't "Monster Garage". And also - are you gonna replace those door hinges for the hatches with something that is intended for a resin bucket of this pedigree? Sweet ride, and these are the rough stages - hope to meet up with ya in Destin, but that's still up in the air for me. |
stecz did you get written permission from the wife for the lake george run :evilb:
i wear the big draws in this house pal.... :evilb: :evilb: |
you tool, every time i see you post you have to say something cocky............i looked at parts you had for sale but after i read posts about the garbage you sell i choose not to..........Dont ruin a good site with your bs.......... PHIL KEEP THE POSTS AND PICS COMING, BAD ARSE BOAT I ONLY WISH I HAD THE MONEY TO RESTORE ONE LIKE THAT........... |
Rat
You have one of the best old school rides out there, fix it up and enjoy it. LS |
rat sink it, just strap your ass in the seat.. :evilb: :evilb:
that rig is bad ass, nothing better then bringing back a bad ass boat... we all cant wait to see that thing.. i just hope you take your time and not rush it.. you still suck, and have to get me and masher drinks.. dont think cause you came to one event you're off the rookie status.. you're off when jc says you are... :evilb: :evilb: :evilb: |
i plan on doing a first class job! i have myself and 2 full time helpers working 6 days a week. im making pretty good progress already. it wont take too much more time to have it ready for paint. a few days to reinstall all the hardware then to sc for the engines.
Phil, I've bought stuff from Fiberglass Coatings in St Pete. Very helpful people there. An old friend of mine owns or owned the body shop right beside them. His name is John Henry. He might shoot the awlgrip for you.
