Paint over Epoxy Resin?
I have done some glass repairs to a bulkhead in the engine/bilge area and I am going to paint it. I purchased white Bilgecoat by Interlux and am curious if there are any special prep procedures or primer that is recommended. Any advise would be appreciated.
Most epoxies usually have a re-coat window of about 24 hours. I'm assuming you're past that. Some epoxy also leaves what they call a "blush" which is a oily feeling film on the surface after it cures. If you have this it must be removed, usually a wet rag wipedown will do it. Let it dry, lightly sand it so you get some mechanical adhesion, wipe it down with acetone and then paint it.
31scarab31
Fiberglass and Paint
11
11-14-2008 01:43 PM
