glass over a sub box thats mdf ?
The reason MDF is used for speakers (even the big dollar companys use it ) is sound quality. Ply is never a good choice for sound, however if you must use ply I would recommend a sealed enclosure with poly filling to soften the kettle drum sound you will get from a soild wood.
The last box I made I used a thin fleece from Jo-ann fabics. Resin coated about 6 times. thin layer of bondo over resin, block sanded, had painted candy and cleared at local body shop. Took about 3 weeks from start to finish, and I would never do it again.
I have built a few mdf boxes with marine starboard fronts. The front of the box was also the back seat base of the boat. They looked and sounded great. Make sure you dynamat the outside of the box that is not visible, stops nearly all of the vibration noise in other parts of the boat.
I still box free air subs, free air just means I don't have to worry about the box being too big, the long excursion VC (voice coil) can handle it. A sealed or ported enclosure sub will have better sound, but in a free air situation the sub will fail as the VC will over extend and ruin the speaker.
08 OPA High Points Champion
good point, guess i never thought of that. Would it work better with a higher ply / higher density like Luan 9 ply? I have always cringed with any type of cast wood product like mdf in the marine environment. I guess its a double edge sword of sorts, either sound quality or more durable box. I know mdf wouldnt stand a chance with the pounding i put my boat through
Keep in mind you can gusset the corners of the box with hardwood scraps, I get mine from the local Stickley furniture factory for free. I use clear silicone for "glue", SS wood screws, then smoot the silicone joint on the inside. If you are concerned about repairs or removal, the silicone makes it easy. For more permanent installations use a high qual constuction glue, SS screws, but also use small wooden dowels to drill and pin the walls together. If my box breaks, chances are you boat is broke as well
The board I have now is MDF but no resin/glass coating and wrapped with vinyl. It is already punky and coming loose. I knew it wasnt kosher when it was installed and planned to fix it myself later. Another thing to think about, the rest of the seat box/floor/supports are fiberglass coated marine plywood or balsa, so really the backerboard for the speakers shouldnt make a whole lot of difference at this point should it?
If I took two good subs, and built equal size boxes...one from ply and one from mdf you would hear the difference, no question. However, if you don't hear the mdf you will never know right?
What kind of subs are you using?
Are they free air, standard. Are you planing on a ported or sealed enclosure?
As I stated earlier, if someone demanded ply and I had to build the box I would make it a sealed enclosure, and fill the box with speaker poly. The poly (like pillow stuffing) acutally effective makes the box bigger as far as sound and air ar concerned. So you will want to make your box a few 10ths of a cubic ft smaller than the recommended for best sound. The poly will help cut down on the unwanted resonence created from solid woods. wrap the outside of all surfaces with dynamat (or roofing membrane if you are cheap ) and enjoy the sound of the speaker itself, not the virbration of the material.
That kid that drives by your house with the trunk rattling, he can't hear the trunk in the car....you will hear both sides plus the boat, that "trunk" noise will ruin your sound quality.
x2 except vinyl. put blocks in the corners for extra strength and some rubber feet on it so the water passes right under it. 2 seasons of splashing and pounding and it still sounds great!
Charter Member #232
If you don't want MDF then you want woods of various densities. Creating your own lamination of wood can be a pain in the butt as well.
Put your best foot forward!
Hey 4bus how bout a product like Coosa or Penske board for an enclosure? It comes in several different densities. Wonder if you could tune an enclosure with this.
http://coosacomposites.com/
