painting a 30 plus foot boat
Anyone ever use pressure pots? How many times are you refilling the gun on a boat this size? I heard the pressure pots help distribute the metallic thru the gun evenly. It looked like the pot set ups (for a decent one) was about the same price as a nice sata or devilbiss. I was curious myself which would produce a higher quality metallic job
I occasionally use my 2qt pressure pot when doing large cat tunnels as they are great for completely inverted surfaces.
08 OPA High Points Champion
I still have my Devilbiss 7 gal pressure pot and gun- we have it on casters so that it follows us around, sorta. Used to paint airplanes with it. When shooting smaller jobs, we'd just set a gallon pail in the middle of the pot- the pickup tube would be in the center of the pot anyway- minimal cleanup! I never shot any metallics out of it other than stuff that was in a gallon pail in the middle as described before, and then there was only about a quart or so of paint in it. If we had needed to shoot alot of metallic material, there was some sort of air-powered agitator system that fit inside of the pot and attached to the lid with a shaft and a propeller on it to keep the flake from settling. Mostly shot aircraft butyrate dope and synthetic enamels (shot 'em hot and they flowed out like glass). Brings back memories....
