99' 32' Fountain Fever - wet sand
Is it worth it to have my boat wet sanded and wheeled out? It's faded from the years in the sun and I don't want to spend 8-10k on a paint job.
depends on how bad the gel is. Try it in a small area and see how it comes out. I wet sanded some fender rash on the black gel of my boat. Scared the chit out of me when I finished sanding. But after buffing with a circular machine and several levels of compound and polish, it came out sweet.
What color is the hull and how much is chalked or faded? There are a number of things you can do besides a new paint job ; You can have the boat wrapped ,there are a lot of new developments in wraps in the last eight months ........The new ones look really good up close because they are a two step process and it is one third the price of a good paint job. You can have the boat buffed out and cleaned and then shoot clear Emron over the glass ......or you can keep buffing and waxing every year until your arm falls off or you can pay some stooge to do the job every year. Or last but not least you can put some really big graphics on the sides of the hull to cover and distract .
Jim
Jim
It's all white, and is no longer a brilliant white. More of a dirty white color on the sides and bottom, the bow is the best looking. It's not very chalky and still has a decent gel coat.
Try Presta Cut, I was referred to it by Off Exc.. and it is some good chit!! you apply with foam compounding pad and it out sweet!! glossy smooth finish then seal it in with Fleetwax. I used to wet sand all the time on my last boat yearly and this is some good stuff. Only did it in spring and it still looks great!!!
if you like the paint scheme... then yes! best way to bring back faded gel we do it all the time
You have it easy being all white ..its a 3 person operation on that boat ,one person sanding one running the hose and a third running a squeege .you will be suprised how fast it goes .if it doesn't have gloss I prefer more sanding and less slinging a Makita .especially on a 30' boat .if not done inside and it prob won't cause your going to make amess ,make sure there is no wind and nobody mowing nearby ,that will help keep thel ittle "pigtails)
