Go Back  Offshoreonly.com > Technical > Fiberglass and Paint
Oxidized gelcoat voodoo? >
Old 01-23-2016, 10:18 AM
  #31
Originally Posted by Tampa Advantage
So sand a reclear only option?
sanding and re-clearing is kindddd of a myth IMO lol
cool product!! i do alot of oxidize gelcoat id like to try it. my system i use is pretty quick and lasts but always open to new systems
315duramax is offline
Old 01-24-2016, 08:13 PM
  #32
Neno the mind boggler
glassdave's Avatar
yep sanding and just clearing is a waste of time. If your going through the trouble of sanding, masking and spraying anything you might as well toss on something more UV stable while your at it. Freshen up the color then clear and be done with it. To much of a crap shoot with just clear over sanded gel, i have seen it work on rare occasions but more often i have seen it make a huge mess with gel actually fading under the clear then you really screwed. If your swing'in a gun anyway why not take a little extra time and toss down color. Doesn't make sense to do it any other way . . . . .
I'm still interested in checking out the system as well VC. Any new info?
08 OPA High Points Champion
glassdave is offline
