Sand Blasting in Place of Grinding Fiberglass
Anyone have experience with Blasting Fiberglass to remove debris , then finish grinding ?
I have a rather large project to recore and would like to cut my grinding time some.
If I could sand blast all the crap off the bottom , then hit it with the grinder to even the surface . I think
I could save about 3 or 4 days of grinding . I Hate to forking Grind......
I don't know if this is the same but a few years ago I saw a marina on the north side of Chicago doing a Soda Blast of a hull-- it was pretty nasty but it was taking all the "gunk" off. From what I remember - it wasn't a very fast process but it sure did a pretty good job.
All the best
3pointstar
All the best
3pointstar
i use a sandblaster occasionally for some specific removal and surface prep tasks but have never tried it for core removal. My thoughts are its more of a surface prep rather then material removal but can take off loose stuff. If used for material removal its difficult to keep the process very even, you could be left with a "hill and valley" surface thats gonna need grinding anyway. I'd say give it a shot and see how it works. I could see it working on core removal like if you cut one surface off and had access to the rotted core, it could be blasted away and if your careful would be left with a surface ready for core but you would have to clean up all the edges. I have used a sand blaster to prep inside surfaces on builds where i went out side the window of the air inhibited property of the resin and needed to wake it back up for subsequent layers.
Give it a shot let us know
you will definitely need a pressure blaster and not the gravity feed bucket type
08 OPA High Points Champion
I'm trying to remove the little bit of Balsa still stuck to the hull , and Some plywood stringer fragments bonded in the strakes .
If I could clean up the edges with a grinder.... Blast the whole surface , and start bagging down core and glass right away that would be bad azz.
I have a 6Cuft Pot with a 185 CFM compressor . I also have a Plastic Media Machine on the way too.
you want a hell of a deal on plastic media? i bought a bunch of items from an industrial auction and in that lot were two 55 gallon drums of coarse plastic media, new virgin stuff. its 16-20 Polymedia Polyplus and it is an over full 55 gallon drum.
this stuff . . . i have around three hundred fifty pounds give or take. I have just been sitting on it hoping to pass on a deal to someone that can use it.
http://www.ebay.com/itm/25-LB-NEW-Pl...-/281278423817
http://www.ustechnology.com/PDFs/poly%20folder.pdf
Have not tried profile blasting, my grinder skills are hyper tuned lol
