Filling transom hole 2"
I did this. trace the bottom half of the existing cut out, Them cut that shape into 2 pieces of 3/4 marine ply and stick the 2 pieces together with resin and mat. Then with corebond or thickened resin glue the piece in. Take wooden dowel of the right size and glue that into the bolt holes. Next take your trusty 4" angle grinder with a 36 grit flap disk and start grinding the inside and out side feathering back 6-8". Then start building it up with 1708 and resin start with smaller pieces going to bigger pieces, Keep your laminate layers as smooth as possible and lay it up a little thicker than you thing you need to, Then you need to grind that back down flush and FLAT on both sides. Getting it flat is the hardest part.
Also helps to take your Bravo jig and put it on the existing cutout and mark your X beforehand as it will help locating your new X
