props for 336 Formula >
Old 05-22-2005 | 08:16 AM
Formula Outlaw's Avatar
Default Re: props for 336 Formula
I was surprised to hear the Bravo props were giving you too much bow steer. First time I've heard of that. If that's the case forget the Hydromotives, they'll only increase that issue.
Hydromotives, as said, are stern lifting props and have worked very well on the older Formulas in most cases. On my 89' 311 they were a tremendous difference over the 3 blade Mirage 23's that came on my boat, I swapped to 24" Hydromotives. Got 7 mph more at cruise and 3 mph more at WOT (gps).
Question regarding your bow steer with the Bravo props and I don't mean to be wierd here. I would assume you are trimming your drives our as far as possible. Just a thought......good luck.
Formula Outlaw is offline
Old 05-30-2005 | 06:18 AM
powerguy's Avatar
Originally Posted by powerguy
Put my 336 Formula in the water yesterday and the 22p hydromotives were definitely the way to go for me. Will a full tank of gas( 150 gallons) and with drives trimmed fairly deep I hit 4800 rpm but did not have my gps on to check the speed. Out of the hole was a breze with no cavitation and I should be able to spin the props to 5000rpm with more trim and less fuel on the boat.
I had tried the 24 bravo 1 and 23 hydromotive before these props. Bravo 1 had great hole shot and cruise but was short on the top end. Hydro 23 could only spin to around 4500 rpm or so. I will post results with 22 hydromotives when I get back out on the water.
My boat has the 454 mag's so with 502' s the 23p hydromotives might be the right prop for you.
Went out yesterday for a quick spin. Boat came out of plane with very little tab needed and cruise speed iwas at a lower rpm. Top end at 4800 rpm on flat glass water and full tank was 64+ mph without really tweaking trim to get every mph so my top end should be the same as it was with the 3 blades.
I have to give "props" to Formula Outlaw as he is right on with the hydromotive Q-IV on older Formula boats.
"All I need are some tasty waves, a cool buzz and I'm fine"
powerguy is offline
Old 05-30-2005 | 07:53 AM
Power guy, can you give us a comparison as far as speed/rpm between the mirages and the hydromotives.
RonS is offline
Old 05-31-2005 | 07:04 AM
powerguy's Avatar
RonS - I have not done a direct comparison by running both sets of props the same day but here is my "seat of the paints comparison". Definitely better on plane with just a little tab needed and NO cavitation. Cruise at 50 mph is 200-300 rpm lower with the 4 blades. With full tank of gas the max rpm is about the same, maybe a little higher with the 4 blades, and top end also about the same speed. Boat definitely seems to run flatter with the 4 blade props. I need to play with trim settings to max performance and ride comfort.
All of that was with a FULL tank of gas. Overall I am very happy with the switch from 23 mirage plus to 22 Hydromotive Q-IV props.
powerguy is offline
Old 05-31-2005 | 09:02 PM
Powerguy, glad those Quad IV's worked out for you.
Old 06-06-2005 | 09:51 PM
test
Old 09-17-2012 | 10:36 AM
Dtile's Avatar
Is this prop the "HYDROMOTIVE INTIMIDATOR Q IV 15 1/2" X 22" " and "HYDROMOTIVE HC-CL22L SS LH"
Anyone test this on the 292 88 non mag? Thinking about trading my bravo 22p for the Hydro's (what sise??), getting only 58mph (4500 rpm) out of them, pre-mirages (Quicksilvers) getting 63 (4800 rpm) but chine walking a bit at WOT. Maybe should have bblades lab the bravos 1's? Both holeshots with both props are great. Are Mirage plus better than the PRE Mirages?
Dtile is offline
32velocity
Northern Illinois Offshore Club
4
03-24-2007 11:57 AM
32velocity
03-19-2007 08:35 PM
32velocity
03-19-2007 04:03 PM
32velocity
Great Lakes and Canada
0
03-17-2007 09:59 PM
DMAX
Prop Talk
6
04-20-2005 05:21 PM
