drives
Old 05-22-2005 | 11:58 AM
mattittuck 1's Avatar
Default drives
i have a 2003 292 fastech and am not sure if the trim on the drives should go higher than 5. With the throttle switch they stop at five with the trailer switches they stop at 8 1/2. I think there is a short that is stopping them but i'm not sure. any opinions would be appreciated
mattittuck 1 is offline
Old 05-22-2005 | 05:54 PM
Formula Outlaw's Avatar
Default Re: drives
I think that they are preset that way so you won't hit the ladder on the swim platform.
Seems to me I heard that somewhere but not certain.
Formula Outlaw is offline
Old 05-22-2005 | 07:30 PM
Default Re: drives
These settings are pre set at the factory, You should not run the drives past the trim setting or you will stress the gimbal bearing, U joint and coupler!!!
formuladude312 is offline
Old 05-23-2005 | 08:45 AM
Iggy's Avatar
Default Re: drives
Like Formuladude312 said, don't run the engine with it trimmed up to trailer position. Besides all noise it makes, the univesal joints don't like it and you could wear/tear a hole in the bellows. Then you'd have a real problem on your hands and give your bilge pump a workout.
Iggy is offline
Old 05-30-2005 | 02:37 PM
TotalMark's Avatar
Default Re: drives
I believe that the location of the trim indicator cables on the transom limit the height that you can trim up the drives on the 292
TotalMark is offline
teaguecustommarine
New Products and Member Discounts
10
02-20-2008 03:05 PM
CAFE
2
12-12-2006 01:13 PM
later
1
05-05-2003 04:57 PM
Dean Ferry
11-27-2002 08:09 AM
