Stellings boxes >
Stellings boxes
Stellings boxes
Old 06-04-2005 | 07:32 PM
RedDog382's Avatar
Default Re: Stellings boxes
Originally Posted by lonestar382
When I got the boat it had 28's, then went back to National Marine for the boxes and came back with 24's.
I guess some things speak for themself.
Hope this works out for you Corey.
RedDog382 is offline
Old 06-05-2005 | 03:32 PM
Originally Posted by Troutly
Corey,
Talk about having the drives buried deep . Not sure you have 3 inches of adjustment there to get them up where they need to be.
Too bad they either did not know what they were doing, or did not care, when they mounted them...
I think you hit the nail on the head with the second statement. Im just glad I got the boat back before the whole National fallout came to a head.
I guess the best i'll be able to get out of the boxes is 2 3/4"s. Anything should be better than it is right now. I am amazed I can even run 70 with the props that deep.
I'm going to take it in in the next week or so and have them raised so keep your fingers crossed.
Corey
lonestar382 is offline
Old 06-06-2005 | 03:09 AM
RedDog382's Avatar
Corey,
Just wondering if you will need to change the engine height, too. The shafts on the Stellings have universals at each end to allow a little angle and a slip collar to allow for length, but if you raise the box that much, will you need to raise the engines also?
I would call Darryl Johnson at Formula TAG and find out if there is any difference in engine mounting for boxed/non-boxed 382's.
Let me know if you need other measurements, but remember I have Merc mounts but not Merc motors in mine.
Old 06-06-2005 | 08:23 AM
I hope not, but I guess since the engines have to come out anyway it wouldn't be a catastrophic event to do. I'll call Darryl and get some insight. I know that on a new boat equipped with boxes, I think the engines are installed 1 inch taller than a non-box equipped boat
Oh Well its only money......right???
Corey
Tibbstoy2
Wanted
0
07-13-2008 10:22 PM
SHAGNASTY
06-15-2005 11:48 AM
CAFE
Fountain
0
04-23-2004 01:52 PM
Douggie Fresh
01-15-2003 02:38 PM
John B
09-18-2002 09:39 PM
