-   Formula (https://www.offshoreonly.com/forums/formula-36/)
-   -   Today in the shop part 2 (https://www.offshoreonly.com/forums/formula/104349-today-shop-part-2-a.html)
Rippem 05-29-2005 07:49 PM
2 Attachment(s)
No, you haven't crossed into an alternate universe...
Too Old is boating (in a Formula no less) and I'm working on mine. :rolleyes:
moved 2 guages, and put in plotter. The wheel is from Trick Marine. :D
Rippem 05-29-2005 07:52 PM
Re: Today in the shop part 2
2 Attachment(s)
the plotter was a tight fit, though I had downloaded the template and sized this all up ahead of the purchase. Tight fit between guages and the "FasTech" on the panel...and the hinge arm on the outside. All is well. :cool:
Rippem 05-29-2005 08:00 PM
3 Attachment(s)
transom stereo remote added (they are standard now..as of '04 I believe). On the other side, are the transom trim switches.
These trim switches should be stock. Great to have at the beach and on the trailer. I've put 'em on my last 3 boats. plug and play, though I had to make a harness extension for the port side to reach around the perimeter to the bulkhead mounted pump for port.
I also made the 4 wire harness for the stereo remote. Tap spliced it into the wires at the dash remote.
I have another one...and am considering putting it in the backseat area. :drink:
Rippem 05-29-2005 08:05 PM
I botched the trim switches sort of. Not as straight and clean as the usual...I'll have to live with it.
You do have to heat the decal up on one, cut out a little half circle with a razoo for the bezel screw. and turn it over (put the switch in upside down)...so the rockers are both on the "inside" for easy "peace sign" two finger manipulation. :p
Rippem 05-29-2005 08:12 PM
the mattress is almost done (see other thread). I've decided to cover it in 2 layers of a "heather" light grey polycotton jersy sheet type material. Soft, breathable, and ....cheap!
six Infinity Reference speakers scattered in the cockpit are the next reason to saw holes in the boat. :evilb:
I have a couple Rockford 10" subs on hand also... :D
Rippem 05-29-2005 08:19 PM
1 Attachment(s)
another Trick Marine goody... :cool:
ThirdBird 05-30-2005 08:20 PM
Your transom is starting to look like a dash board. Oughta just mount some throttles and a wheel back there and you'll never have to get onboard!!!!! :eek: :p
Rippem 05-30-2005 08:32 PM
:D :D
dukenrock 05-30-2005 08:40 PM
Too much work, not enough play! Looks great Rip. Get that thing in the water before Too Old's hour meter starts to pass yours! (Let's see the carpet!) :drink:
Downtown42 05-31-2005 05:05 AM
looks good. you're trim switches look fine straight to me in pics.
